christianprogrammer
Material Stuff just turns to ash
Japalura 4" was all happy (sans tuning) when I popped the mini
antennae connection on the VTX . Yes the actual circular mount so I couldn't just pop on another antennae. The VTX is a VTX 03 , I try to keep a few around just in case and replacement antennae. Unfortunately the JST connector to the run cam swift is an odd 1.25 not 1.0 mm and I don't have a ton of those lying around, and for some STOOPID reason the VTX03 ships with a 1.0mm throw not 1.25 the one in place was already piggy backed ( lineman splice) to get her to the camera from the VTX.
So I had to do that again for the replacement and now my smoke stopper screams and lights up when the camera is attached . Solder and heat shrink is all good...
Could the horrible length of the three wires from VTX to camera be a problem? Of course the power and ground ( two more wires ) from the VTX to the FC are also now spliced up since I already had them hot glued to the FC . potential problem as well ?
I appreciate any and all insight thanks
