Smokey
So, I seem to have the battery issue sorted. The only other problem I'm having is vibrations/wobble.
Having done a bit of research it appears this could be attributed to one or more of the following:
1) Props need balancing
I have purchased this prop balancer (http://goo.gl/FVC2Cw) but unfortunately my kit came with the self tightening type props, which I can't balance using that particular bit of kit, so I may invest in some decent carbon ones and see how that goes.
2) Engines need balancing
Really hoping I don't need to go down this route!
3) 4 cell battery with 10inch props.
I don't think it's that. As you can see, I am using my 3 cell battery, and there still seems to be an issue. That said, the wobble is enhanced when I use my 4 cell.
4) Gains
I really don't think the wobble I'm experience is down to gains, but will be experimenting just in case.
Anyway, please do cast an eye over my video and let me know what you think might be the problem.
Video: https://drive.google.com/file/d/0B9lp8l2s1ebrR1JnOVlaZHo2Q2c/edit?usp=sharing
(you can actually hear the wobble better than you can see it)
Thanks
4) Gains
Thanks
