wafflejock
Overall initial impressions are I love it. The telemetry has given me some low signal warnings so I am curious what actual point is that it drops out but luckily so far hasn't happened, might be overly sensitive settings for RSSI or I've just been lucky so far.
Only gotcha I ran into with setting up is if you change to a "locked" channel on the VTX (any Raceband outside of 4-6) then the VTX just turns off basically (stays hot but no signal transmitted). Unlocking is easy enough or sticking with the default R4 channel is fine if flying alone but buddy and I both got one at the same time so it's nice to fly together and not be near each other in frequencies so I did unlock mine (also bumped from default 25mW to 100mW) Can see signal is pretty good IMO for a tiny little guy like this.
