Taranis question
Discussion in 'First Build' started by aviscomi, Dec 24, 2016.
  1. aviscomi
    aviscomi Member
    Okay, after 12+ hours of try this now I'll ask for help: I have a Taranis+ and just finished build a QAV-R from a kit received from FlightClub. My issue is that the frSky X4R doesn't seem to be receiving a signal from the Taranis. Though the Taranis is receiving fro the X4R (i.e. Telemetry). There is no problem with the Taranis because I use it for another racer. I used a Cleanflight file that I received via flightclub along with the taranis file.
    I am open for suggestions...thanks!
  2. ringolong
    ringolong Well-Known Member
    How do you know that there is nothing being sent to the rx?
  3. aviscomi
    aviscomi Member
    Because when I look at the remote config in Cleanflight none of the bars/graphs are moving when make an action on the Taranis
  4. holtneil
    Hi mate have you bound the transmitter to the receiver first
  5. aviscomi
    aviscomi Member
    LOL...yes I did
  6. holtneil
    OK are the channels map right receiver to FCB
  7. aviscomi
    aviscomi Member
    Don't understand
  8. holtneil
    are you going S-bus or full wire connection if S-bus make sure the FCB has its S-bus turned on
    I think there is also a setting in the transmitter for S-bus
  9. aviscomi
    aviscomi Member
    Pardon my ignorance, but I made my connections as per the instruction from Flightclub. This is my 1st build. I am using the small port on the side of the X4R for my connection
  10. ringolong
    Holt is all over it. Sounds like a configuration issue. That's why I asked how do you know is being sent :)
    Check out this video.
    holtneil likes this.
