If there is no card in the slot the camera will not power up.
If the card is bad, it may not power up. Try a different micro card
Cheers mate i will try that thanks for the helpWhen I got my X5C-1 one motor did not work.
Instead of sending it back, I looked inside and found a wire that had not been soldered properly and repaired that wire. Since then it has flown nicely.
If, after formatting the card it still won't work, you may need to open the chassis and look for a similar problem. After checking the plug for bent pins etc, of course.
Did you closely check the gears? May not be the motor.hi did all that no wires off put it all back know one of the motors not turning very fast its binding so it wont fly
Sorted it put the propellers on wrong damn I'm a spanner
Cheers matethanks for your help just been out with it it's so good just got to get a new camera know
I can't just takeing a chance I got a board coming
