doug micheletti
Hi,
First post, new to copters. I have been flying planes since early teens (I am now 60) - control line to RC, but have been Idle a few years and much has changed in the hobby.
I purchased the SK450 about 1 month ago.
On initial startup - it would not arm, followed by the KK2 going to blank screen, and then smoking.
KK2 was burned up.
Hobbyking replaced it, but then it would not power - the #1 ESC also got cooked.
Hobbyking replaced it.
I now experience where the copter will run all the motors, but the #3 runs about 1/2 the speed of the others, and coasts to a stop after running briefly.
Holding Copter in my hand - I feel it twist when opening the throttle - it would flip in flight.
I purchased the Turnigy Multistar ESC programming card - Can anyone provide the correct settings for the ESC's on this copter? I would like to get everything set to be all the same to verify if problem is hardware, or operator.
I could also use correct settings for the KK2 for this copter - I think I have it right, but I am a newbe so could very well have something set wrong.
I just want to be able to verify where the problem is located so I can go FLY!
Any help you can provide would be appreciated!
Doug
KK2 was burned up.
Doug
