Tomyoder66
Has anyone ever separated the tower in order to use the top half(fb)? I am trying to figure out the connections. The pin layout is (left to right top then left to right bottom)
Vbat, battery+,vbat, battery-,ground
Bottom
Ground, signal1,signal2,signal3,signal4
I have hooked up the battery+ and the ground on the bottom to the 5v from my pdb. And signals 1 thru 4 were easy enough to get. I got power and the motors spin using the ez gui app on my tablet. My questions are these... Does the battery+ need direct connection to battery? This appears to be a connection for the FB and I don't want to fry the board with 12 v. Also where do I connect vbat to? Do I need to connect the two vbat to separate deals or what?
Anyone?
Bottom
Anyone?
