NielsH
Hey, I recently built my first quadcopter. Everything works fine when I test using the software on my computer. The engines run well and smoothly and I see no problems. I also have the drone tested at full power with and without props to the computer. I could not find any problems. Because I thought that maybe there was an imbalance in my props but that was not the case, or that one engine was bad. I have a little clip of my drone during minimal ability to come up a little but i cant post it for some reason. this is the link for the video! :
My specifications are below my drone Before I had this problem, I had a slight drift to the left but I did not so much because it was easy to solve send a little. But now it's really bad.
Specs Drone:
- 4x Emax RS2205 2205 2600KV Racing Edition
- 4x Favourite FVT LittleBee 20A-S ESC BLHeli_S OPTO 2-4S
- 1x Matek Mini Power Hub Power Distribution Board With BEC 5V And 12V For FPV Multicopter
- 1x F3 EVO Cleanflight Flight Controller for Multirotor Racing w/ 4G MicroSD
- 1x Kingkong 210 Lite 210MM Carbon Fiber FPV Racing Frame
- 4x quad blade prop 5 inch.
controller specs:
- Flysky 2.4G 6CH FS-iA6B Receiver PPM Output With iBus Port
- FlySky FS-i6 2.4G 6CH AFHDS RC Transmitter With FS-iA6B Receiver
If you need more info i love to provide that!
Thanks for your time
-Niels Hoffland
Specs Drone:
controller specs:
-Niels Hoffland
