Using
Spektrum DX6i
Naze 32
250 frame
My quadcopter docent respond correctly to my transmitter. I can get my transmitter to bind to the receiver but then after I turn everything off it wont connect again(I took the bind plug out after it was connected).
So then I just left the power on to transmitter and the receiver so they were connected and used base flight to see if the transmitter was working and it was. I check the motor with base flight and they all work at the same speed. So I go out side to see if the motor will spin up with propellers on now. The first time i did it some of the motor worked and then the other stared later with more throttle so I went back to the computer to check everything and it all worked with the program. But now the board wont arm and the motes will randomly glitch out or spin up and I have no idea what is wrong.
Spektrum DX6i
Naze 32
250 frame
