Hi,
Im a complete newbie, and instead of buying a quad I went all out to build one. The quad is built but Im needing help with what I believe to be transmitter setup.
The quad components:
Turnigy D2836/8 1100KV Motors
Turnigy Plush 30amp ESC's
Hobbyking kk2.1.5 flight control board
Turnigy 6xs transmitter with Turnigy XR 7000s receiver.
Iv set the flight controller up for X configuration and all motors and props are going in the correct direction as per the boards display, However the quad is uncontrollable.
Without making any trimming adjustments the board receiver test is displaying when all the thumb sticks are in the idle/neutral position:
Aileron:18 Right
Elevator:19 Back
Throttle:0 Idle
Rudder:1
Aux: No signal
I have tried sub trimming on the transmitter to zero these to see:
Aileron:0
Elevator:0
Throttle:0 Idle
Rudder:0
Aux: No signal
When the thumb sticks are in the idle/neutral position.
However as I increase the throttle to 50% I see:
Aileron:-16 Left
Elevator:-16 Forward
Throttle:49
Rudder:0
Aux: No signal
And as I increase the throttle to 100% I see:
Aileron:-63 Left
Elevator:-63 Forward
Throttle:100
Rudder:0
Aux: No signal
Im under the impression that when I engage throttle, only the throttle should move, instead of sending my off in all directions. The Turnigy 6xs does not have a quadcopter model setting, only helicopter, plane, v-tail and delta.
Can someone help me out please..
Aileron:18 Right
Elevator:19 Back
Throttle:0 Idle
Rudder:1
Aux: No signal
Aileron:0
Elevator:0
Throttle:0 Idle
Rudder:0
Aux: No signal
Aileron:-16 Left
Throttle:49
Rudder:0
Aux: No signal
Aileron:-63 Left
Throttle:100
Rudder:0
Aux: No signal
