cdudukovich
Hey!
FC: pixracer
MOTORS: Turnigy aerodrive D2830/11
ESC: dys xs 30a
I'm robotics club is working on a custom drone and we have run into some problems. We are using qgroundcontrol and after setting up the sensors and radio we attempted to calibrate the ESCS.
When we start calibrating it says "you must disconnect the battery prior to performing ESC calibration. Disconnect your battery and try again". The problem is, the battery is disconnected.
The only thing connected to the flight controller is the USB cable and we have attempted using multiple ones. I have no idea what could be causing this error
Thank you for your time!
FC: pixracer
ESC: dys xs 30a
