HI mate not really, it depends on frame size, power of motor , if you use ecalc you can try different size blades on your set up and watch flight times change , one thing is say you use 10x4.5 prop and want to go to a 3 blade prop drop the size by an inch http://www.ecalc.ch/xcoptercalc.htm?ecalc&lang=en
