Eastbayboy
I am trying to set up a iFlight Succx-A10 F4 flight controller with BetaFlight and was hoping for some help.
I initially hooked up the FC to BetaFlight and all looked well. When I moved the Quad around the Setup page display showed the quad moving also.
I then successfully flashed the FC with the lastest software. I then went back to the Setup page and the display was not moving when I moved the quad. Connected/disconnected serveral times, rebooted the computer and Betaflight serveral times with same results.
I then went to the CLI page and typed in 'VERSION'. The correct version was displayed but also an ERROR was displayed.
###ERROR: VERSION: NO CONFIG FOUND###
Only the USB was hooked up during this time.
I also noticed on the BetaFlight Configuration page in the Board and Sensor Alignment section "Warning No Gyro Detected". The FC contains a gyro.
Any help is greatly appreciated!!
Eastbayboy
Eastbayboy
