Hi there,
I am thinking of investing in a Turnigy Reaktor 300W charger to charge my 6s 10,000mah lipo. However, I can't find a power supply.
It says that to acheive full power it needs an input voltage of >18v. I then roughly calculated that if a power supply outputted 18V at 20Amps, the power would be 360W, enough to power the charger.
Is this correct, and can you recommend a good power supply for ideally under £60.
Thanks.
Thanks.
