So I just finished up building my quad with sunnysky x2204 motors, but when I am trying to mount my props there is not enough thread to fasten the props! The issue only occurs with the ones with ccw threads. Please help!
Hi mate what props do you have they should fit the right way up , so by you saying they fit only upside down they must be the wrong props ( are they DJI phantom blades ) as these are stepped in the prop hub
Hi mate be careful you dont go off centre , gemfan are normally really good I use them all the time , I would check the motor mount size , have you tried to talk to sunnysky it may be mount problem and your slipped
Shaft size should be 3.17mm
Some thing is very strange the props come with a ring to make them 3,17mm
this may sound stupid but there is not an adapter ring stuck in the hub bottom so stopping it from fitting
