I just purchased the Naza V2 system for my DJI F450 quad. I reviewed the instructions and found that the U-Channel slot on the flight controller should be connected to a slot on my RX701 receiver that corresponds to a 3 channel position switch on the transmitter.
I use a Devo 7 transmitter with the RX 701 receiver.
Which slot on the receiver should I connect to the U-Channel slot on the Naza controller?
I currently have the u-channel plugged into the "gear" port on the receiver which I believe is incorrect because that is a 2 position switch.
Any help is appreciated
