mavic pro crash ,motor or esc to blame.
Discussion in 'RTF Modification & Repair' started by Mark Parnell, Aug 1, 2018.
  1. Mark Parnell
    Mark Parnell moss99
    Hi all , i had my mavic pro crash recently due to the rear left motor stopping looking at the logs iit appeared the motor was still getting voltage but the current dropped , in testing the motor it seemed a little tighter to turn than the others but spinning it ant testing the output voltage it seems to be the same across all phases and winding's seem ok testing with millivolt meter .
    Here is a screen shot of motor speeds ,current,volts .
    The esc temps seem pretty much the same .
    I have replaced the motor but not sure if i should replace esc bord too .
    Here is a link to the full log .
    I can post the link to flight data if required .
  2. RENOV8R
    Why didn't you contact DJI regarding the issue, no warranty?
  3. Mark Parnell
    Mark Parnell moss99
    No , no warranty or insurance , i sent logs to DJI , they just want me to send it for repair which will cost a small fortune no doubt , its almost repaired i'm just not sure if i need to change the esc
  4. RENOV8R
    If you've replaced the motor and it operates properly now, I wouldn't worry. Except in rare instances, ESCs either work or they don't. There's no in-between
  5. Mark Parnell
    Mark Parnell moss99
    I have not tried it yet , i am waiting for the GPS/compass module to turn up , im just trying to understand what went wrong .
  6. mozquito1
    What's up mcfly, you a chicken.
  7. Mark Parnell
    Mark Parnell moss99
    It wont start without both compasses , so it seems .
  8. mozquito1
    Bummer:( no disable.
  9. Mark Parnell
    Mark Parnell moss99
    not that i can find .
  10. mozquito1
    Threaten it with a soldering iron.
    Only hold it like your going to stab someone though. :mad: works for me.
    Dji should rename themselves to Jpi
    Just Post It.
  11. Jake Jhonson
    Jake Jhonson Well-Known Member
    Pilot Error = No Warranty
  12. Jake Jhonson
    LOL mozquito :D
  13. Mark Parnell
    Mark Parnell moss99
    pilot error ! , not sure how i stopped the rear left motor from spinning
  14. RENOV8R
    Doesn't matter, OP didn't have any warranty to start with
    Jake Jhonson likes this.
