christianprogrammer
Material Stuff just turns to ash
OK so I thought I had figured out something cool.. I want flight modes on the three position switch . It's just a FlySky Fs-i6 the receiver is the default 2.4G 6CH FS-iA6B
that comes in the ready to fly Wizard from GoodBang (lol) . However I thoroughly checked the orientation of the props ccw vs cw. Then the next issue is the motor rotation. I somehow stupidly have set the first switch to not only ARM but swap the motor rotation each time it reaches position #2. Im a real noob so I don't know how I pulled this off in betaflight or on the transmitter. I thought I had successfully set a few modes on the three position switch SWC and the Arm to the first switch SWA. I seriously checked this several times in BetaFlight nut didn't notice the rotation change. TEST start her up default to arm no motor rotation SWA in Pos#1. Engage SWA to Postion 2 motors rotate back a$$wards.. ( I didn't have the props on for the revelatory discovery here but...) switch SWA back to Pos #1 then back to Pos2 and they are rotating correctly ( I think .. I didnt check ALL the motors at that point I was soo amazed at what Kraziness I had managed to pull off) I was just monitoring one motor to make sure it was rotating in its correct orientation. but I believe they are all switching direction in the steps I described .. What Did I F Up and how do I fix it ... FC Board appears to be a Flip 32 clone on this round from Bang Good..
