I did it!!!!
Discussion in 'Newb Guides' started by dragger201, Nov 23, 2017.
  1. dragger201
    No not that!!!
    Anyway, got one of these..........
    https://www.ebay.com/itm/QAV250-Qua...e=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649
    to build my 250mm quad. What a nightmare trying to figure out why it wouldn't connect. First, it's not got the MultiWii firmware, it actually had Cleanflight 1.11.0. But just could not connect with any of the configurators. I had originally installed this......."CP210x_Windows_Drivers" and thought I was good. But no matter how many times I ran Zadig and ImpulseRC and several other apps, just could not get the FC to talk to my PC. I downloaded and installed the "STM32" drivers...........again. Then in recovering old ground I discovered.........."https://www.silabs.com/documents/public/software/CP210x_Windows_Drivers_with_Serial_Enumeration.zip"........but the installer didn't work so I went to Device Manager, did an "Update Drivers" and manual selected the folder with the "Serial Enumeration" and VOILA..........FC talks to PC. So flashed the Betaflight firmware but when setting FC up, notice my baro was gone. But had enough for one day and just reflashed FC with Cleanflight 1.14.0. When I can find something definite on what the latest firmware I can flash on Rev 5, I'll reflash with the latest. Or maybe even see about using Betaflight if I can get my baro sensor to work..............
    [​IMG]
  2. Rick M
    I gotta hand it to you, you're persistent! I'd definitely recommend flashing with Betaflight. And that had to be a lot of soldering!
    dragger201 likes this.
  3. dragger201
    Naw, Rick........no soldering involved............thankfully............
    And yeah, once I figure out turning on the baro and compass I'll definitely be flashing Betaflight................
  4. RENOV8R
    You'll be able to enable the barometer in the Betaflight configurator
  5. dragger201
    Yeah, I found out how to do it about half an hour ago, but 4 hours straight this morning........I'm taking the rest of the day off...........
    Rick M likes this.
  6. RENOV8R
    Hahaha information overload, brain shutting down......................
  7. dragger201
    Exactly....................
  8. ArmyVet
    ArmyVet Well-Known Member
    Not sure why I found this appropriate............But resistance is futile:eek:
    [​IMG]
