Ok so motors are right and props right , are all motors starting at the same time if not, adjust the throttle sub trim in the transmitter so as you raise throttle they all start the same time , what FCB are you using?, most will do a sensor test so check all is ok, did all esc calibrate ok ? did you calibrate sensors this must be done with quad 100% level also may sound strange are all motors new and the same ?
