W.W.
I build my first quad today and went to test fly it. When I took off everything was fine except for some oscillation. I gave it a quick burst of throttle and one of the props flew off. At first I thought it was a loose nut so I put the prop back on and took off again. I wanted to replicate the result so I could figure out the problem so I gave it a quick burst of throttle and both props across from each other came flying off. After some inspection I realized that as it spun it unscrewed the nut on both motors. I'm wondering in I need counter sunk shaft/screw or if a medium strength loctite will hold in flight but still be able to take it off if a prop breaks.
Thanks, Ivan
Thanks, Ivan
