I believe you can, I use the FatShark V3 for my phantom, you will need to adapt the standard HDMI to the V3, it uses a mini HDMI Input, once you get it hooked up just select the appropriate display and should be good to go. Not sure never tried it, you will only get 720P resolution from the glasses.
