ESC issue?
Discussion in 'Flight Videos' started by Eric, Sep 3, 2018.
  1. Eric
    Eric Well-Known Member
  2. mozquito1
    You sure it wasn't the rx. I could hear the motors spinning alway to floor. Couldn't tell really.
    Eric likes this.
  3. Eric
    Hi Mozquito1, not that I could tell. I replaced the ESC's today and almost had the same issue. I'm thinking iot may be a brown-out. Going to do a thorough maintenance session on the bird.
  4. mozquito1
    Maybe change the antenna placement.
    Have you got a single or diversity rx.
    In my experience other than to totally kill an esc, I've never had an esc on its own just stop working mid-flight. Even cheap ones. Do you use airmode.?
    Eric likes this.
  5. mozquito1
    Possibly even voltage sag. The same thing happened to me every flight until airmode came out.
    Eric likes this.
  6. Eric
    I'm going to do an overhaul, clean it up and check for bad solder points. using a X4R RX and using a Kiss V2
