Hello,
specs:
Eachine racer 250 pro RTF version w/eachine i6 tx and eachine i6 rx
I am just starting out in this hobby and had my first significant crash. I believe I damaged the rx so I attempted to order an eachine replacement only to find its impossible to order one. As I understand the eachine i6 transmitter is just a rebrand of the fly sky version, is that correct? So I ended up ordering an FS-iA6 receiver to replace the eachine i6 receiver because the info I could find claimed that the two are identical. however I have had no success in binding the eachine i6 tx to the FS-iA6 rx. Does anyone know if they are actually compatible? Visually everything looks exactly the same. I have created a new model in the tx to bind and that hasn't helped. I can get the rx to change from rapid blinking light to slow blinking light during binding so it does seem to bind, but when I hook everything up to actually use it it does not stay solid light and no response. So compatible or no? Thank you !!
specs:
