I started to remove the top canopy of the -1 and soon found that it's now all one piece.
I wanted to poke the antenna thru like you can see just above the Syma writing on the black one.
So , since the center canopy can't be removed and I didn't feel like taking the whole thing apart ,
I'll leave it the way it is for now. It's probably slightly stronger with the one piece top.
Note : The battery socket can be removed from stock position with a small screwdriver and a little patience
with out taking the top off. Remove the battery door just to get it out of the way. I changed mine over to a
std. JST female connector so I can use the Dromida 700 battery.
Use an E Flight EFLA243 which has HD 20 gauge silicone flexible wire.
No , I hadn't changed the connector yet in the picture and the JST connection
does fit under the stock battery door.
