Darkmax Receiver problem
Discussion in 'First Build' started by Garpee, Nov 30, 2017.
  1. Garpee
    Garpee Member
    Cant get the receiver working on the furibee darkmax
  2. mozquito1
    What Tx & RX is it & what fcb, I can't tell from the video. Would be better with a picture of the board. Sometimes a picture speaks a thousand words & a video speaks a thousand pictures, Sometimes.
  3. mozquito1
    Sorry I only access this site through my Android phone. Sorry, can't see properly.
  4. Jackson
    Which one did you get?
    This one.
  5. Garpee
    Garpee Member
  6. Garpee
    Garpee Member
  7. Garpee
    Garpee Member
  8. Jackson
    Did you go into the i6's RX setup and set AFHDS 2A to OFF?
    mozquito1 likes this.
  9. Garpee
    Garpee Member
    yes
  10. Garpee
    Garpee Member
    You can see the same problem here. at 6min. However this did not work for me...
  11. Garpee
    Garpee Member
    it could be mah bad soldering whos causing the problem
  12. Jackson
    I'm confused by the vid, since Betaflight directly supports IBus, why the soldering to the sat port? Can't you just connect normally to the port and just set BF to IBus.
    [​IMG]
    Then look in your CLI commands and invert the port.
  13. Garpee
    Garpee Member
    And how do I invert the port in my CLI commands?
  14. Garpee
    Garpee Member
    and how do I do that?
