Contixo F6 Battery Problem, Need connectors
Discussion in 'Parts & Components' started by dvsgod, Dec 6, 2017.
  1. dvsgod
    dvsgod Member
    So I ordered 2 Contixo F6 quad Drones based on GadgetInspectors youtube review I watched, and some others I had read. After doing so I ordered batteries from another source based on the pictures the seller supplied for the connections, that correlated with those of the video and images from reviews around the web. I ordered 6 batteries in total as extras. I was under the impression from the pictures they had posted within the item description and the video, that the batteries would connect to the quad by the same connector that charges them ( the balancer Connector ) come to find out, now they have a newer 2 prong jtc connector, secondary to the balance connector (shown in picture), that I cannot even find anywhere to change the ends if I wanted to. They shared the same battery with the Syma X8C, now the quad itself has a different connector then it used to, wich did not show in the advertising. I could use your help in this situation. I would rather not return and go for my third choice in the holy stone 181c. My first choice was the Contixo F18 but the proprietary battery held me back from the extra expense, seems I'm in the same shape as of now with a proprietary plug. Id rather not go through a return process. Would anyone happen to know what type of connectors these are, where I can find the connectors, or a close battery purchase price? The batteries I purchased were 3 for 25.96 shipped, and I purchased 2 for that deal. Ive been doing r/c for a long time so I understand what I may be working with, but these were the correct battery before the plug change on the quad, same quality just new connectors. I thank you in advance for any ideas and your time and hope to here back soon.
    F6 battery on left, Purchased on right.
  2. dvsgod
    dvsgod Member
    Here's the plug port on the drone
  3. dvsgod
    dvsgod Member
    If someone knew where to get these exact ends I could just make the adapters for the syma batteries
  4. Jackson
  5. dvsgod
    dvsgod Member
    Similar but not quite. the closest ive come across is the jst-xh, but they are different. do not have one to check size so may have to spend the 5-10 bucks for some and try. heres what they look like and where the difference is
    heres the jst-xh 2.5mm
  6. Jackson
    It's always a problem when you buy those Amazon rebrands. They are usually old stuff and not even available anymore by the real manufacturer. A lot of times they were made by JJRC which is why I posted that link.
  7. dvsgod
    dvsgod Member
    well, i came across another of those that you posted with another angle, and it looks really close just with the squeeze wings on the side
  8. dvsgod
    dvsgod Member
    that's a no go
