Okay, so i have a 5" quad with t motor f40 pro ii 1600kv motors, hobbywing 20A esc's and the dys flight controller. i had a bit of trouble getting this quad to fly to begin with but eventually i got it working and started to learn to fly it, i have had about a month of flying and it's been going quite well, but a couple days ago i took my quad out and put it in acro mode, throttled up and it flipped straight into the ground, it does this even more violently if it is in angle mode. I took it home thinking i had put my props on wrong or something, but no, it all looked right, so i took it into my garden to try and fly it again, and noticed that if i throttle up slowly its fine, and if i tilt left and right, etc. its fine, but when i give it enough thrust to lift off, everything is sooo sensitive, wayyy more sensitive than before, i know there hard to control, but i cant even hover it, i'm really annoyed as i have just started to enjoy this hobby and now i don't know what is wrong with my quad. I still don't think i've explained it well enough, but any help would be greatly appreciated.
Also if i connect my quad to betaflight, sometimes the accelerometer is completely off, sometimes upside down, so i re-calibrate it, and it seems fine, but when i move my quad, the 3D model doesn't move. could this be anything to do with it?
thankyou so much in advance
Dylan.
Dylan.
