QuadKid
Noth'in Like a Flat Top
For the life of me I can't figure this one out. Built a new Martian 22o used a Omnibus F4 v1 FC -flashed with BetaFlight 3.1.7 . Configured it fine, went flying a few packs, flew great just wanted to tweek a couple things, went and plugged it in > no connection to FC, it was connecting using comm 6 now it's dead, will not connect, it still flies, if I use a 3S battery > no problems, use a 4S battery 1st pack all good, 2nd pack putting thru the paces about 2 minutes flying it just falls out of the sky. It's almost like something is heating up when punched and disconnects. Bring it back use new 4S and the same thing happens @ around 2 minutes in, tried fresh pack and flew non aggressive, easy in the throttle and had no problem, this is the first time I used DShot 600, any sugesstions?
