kookoocachoo
I went to calibrate the 4 escs in clean flight on my quad and when I did, motor 1 started twitching without the battery even plugged in(its the only one that doesn't have bec removed if that matters). It happened when I put the throttle to full using the master slide, and then I was supposed to turn on the transmitter and plug in the battery, wait for the beeps and put the throttle down to calibrate the escs. I tried it with the twitching motor and the moment I plugged the battery in it was the only one that actually started spinning full throttle which it's not supposed to do. Why is this motor twitching? Could it be the wiring, or because the naze board has its own bec and I left one in on a esc? I'm following the naze32 rev6 setup from flite test on youtube(part I'm at is 10:00). I'm using emax 12a escs, and emax 2300kv motors. Here's a video of the problem and pictures of the wiring:
