Soros Gyula
Bayangtoys X16-As the cheap cheerson clone
Packing
Drone will be received in paper box as usually, which open in right side.The packing inside is size cutted polisteren piece where the pieces holded with glue tape it protecting well.In front of on pack we will get technical informations except from above ,where could found multilanguage safety instrucitons.
Parts os the box: The drone, transmitter, monitor holder, camera, 4 pcs extra propeller,4 pcs landing gear and screws for it,3S battery and charger for him.
Outside(
The drone frame for tapping is like cheap plastic, which probably when crash it will be (zlomil to ,nepride teraz na um.)
If we seen it from the upper could see four motors and fake GPS tower and some of marks which want to show the quadcopter sides. As left and right side we couldn’t found any specific. From front not so much possible to see only camera lense, from back place for battery and plug as usual using in walkeras. And as last from below now there is special because you get an ON/OFF button ,which doesnt saw many years ago. Next we could found the camera which is in "gimbal".The camera was connecting to camera with 2 side jack plug this is unusual too...And in every arm we will found a LED lights, front light red and from back light white with these also want the copter sides.
So lets dissamble...
If you want to disable need to get off 36 screws.Inside the drone in middle of is the motherboard at arms the motors and the ESC, where changed how placed the ESC in non ugraded there is turned into left side, in ugraded it placed horizontally.As from motors ,we couldnt know anything because is there something no brand motor as the battery...Interesting for LED lights is able to another electric board which in other copters I coudlnt seen.The hovering was possible thanks to barometer in front of the quadcopter under the black plastic,but it need to ugrade....
Motors...
As from motors side we get some unbranded model, which I guess as technical specificatios its around 1000kV-1300 Kv. As reaction everything goes fluently not recognized latency.Energy was receiving from 3 cell battery ,so motors are powerful from this side.Need to say some words about ESCs too.Unfortunatly without measuring we will get an 20 A model ,but brand will be never know really.Interesting too that the motors protected with some of protecting legs under the motors which is good idea.
Camera and gimbal
For both we will get a low quality model, which usually in low end 50 euro drones, but need to discount with something, right? However good news there is a socket in copter body so with correct plastic camera socket we could add there an action cam, without any king of problems.
The camera lense is cannot moveable with contoller so if you want it need to use human power,because the gimbal moveable part is very small and it stucked with holding screws and because them it lose from their mobility. As using we will get 480 p quality and with 60 degree see (uhol), which is very unstable thanks to low quality gimbal and for weak software solution. Unfortunatly the antenna which went out its not the best too as the factory promise around 300 m, really get only 100 m, but somewhere its hard to get it (at near the forest I was could move only 30 m, because after them the video signal was over.) The recorded photos are stored in microsd card.
Transmitter
As usually we will get only basic funtions (headless,return to home,3D flip). Some button for example in front panel left as we hold it it cannot reagate and the smae problem in circle left button. As assembly I couldn’t have any reason to review in negative, the plastic not giving a sound after give it to hand powerful and if touching more powerful the front plastic panel it will woudn’t reagating another buttons. Az energy 6 pcs AA battery hold on. As if we dissambly it we could see things as usually as one piece of motherboard with lot of switches unfortunatly with some non working buttons I not seen that never in quadcopters however maybe designers in China thought it looks better, but he good news is have a modulator soldered to motherboard, not only one cable. The next bad thing is the FPV which receiving with quadcopter its not compatibly because when try to push in antenna, where need to assembly it will be crash I think it need to rethink and ugrade again (what a bad idea blocking a signal with a plastic FPV monitor.)
Test Flight
If we want to arm the drone we need to move the first joystick left and the second right, but before them need to switch on/off button to on position, because only with them the motors start if will add more throttle. Good news he really could hover, but due to missing GPS need to always corrigate it vertically. The FPV picture its only enough approx 100 m as the control distance is more better. As battery we will get around 12 minutes flight time, which could use it effeciently as the special features as 3D rollover, return to home (where going back in straight line where easy could stucked and could move over the home point.)
Unfortunatly in my situation I getted a fatal error, where the quadcopter was crashed without any signs of errors before and after. As the second test it taked off and immediatly turned left and went there as they it found an obstacle and broked leg. It’s could possible only I was received this model with error and the others are good. But for ending buy with confidence.
Summa summarum:
As the quadcopter no problem, however some parts need to rethink and ugrade as see the camera, but for his prices 120 euro prices need to accept these limitations as absection of GPS...For ending it could be great for beginners, but it couldn’t add back the flying fun fully.
Packing
Outside(
Motors...
Camera and gimbal
Transmitter
Test Flight
Summa summarum:
