Are you flying fpv do you use betaflight? if so you can add to osd. There are also small lipo checkers with buzzer that can be set to go off for low voltage alarm assuming the battery has a balance cable you just plug it in there.
This a great two in one tool that gives a loud alarm at low voltage and can quickly display battery voltage. Simply plug a 1-8s battery's balance connector...
