I'm a nube and recently purchased the Arris c250 rtf fpv package. It worked fine until the battery slipped off the back and caught one of the props cutting it up. Fortunately it wasn't high up in the air, it fell about 5feet when i cut the throttle. I inspected the quad and found no problems visually. 3 weeks later when new batteries arrived i thought everything was fine, plugged in the battery the esc's engaged, but when i went to give it a little throttle nothing happened. So went home plugged it into cleanflight and everything works motor spins when i engage it with the computer, transmitter shows movement on screen when i throttle and pitch and roll and yaw. The transmitter is a Flysky FS-i6 that came with the copter. I need help, any suggestions or support is much appreciated.
