1. NOTICE: We're currently noticing some EMAIL DELIVERY ISSUES to Outlook and Hotmail email addresses. If you're a new member and don't receive your confirmation email, feel free to reach out to us via the contact link at the bottom right of the page.
    Dismiss Notice
Arducopter flips on takeoff
Discussion in 'Newb Guides' started by DannyV, Dec 4, 2016.
  1. DannyV
    DannyV Active Member
    Good evening all,
    I know there are tons of these "flipping on takeoff" threads, but none have solved my problem. I've checked motor location, motor rotation, propellar rotation, calibration, fc (ardupilot 2.8) mounting direction, compass direction, ESC calibrated automatically and manually (one at a time), and weight centered. But yet, its nearly off the ground and already tipping sideways! If anyone has any idea of what is going on, please help!! I've seen threads talking about logs, but I'm really new to this so I don't understand anything about downloading logs or how to read them. I also don't know the language used in terminal and how to communicate with the board through the terminal. I have tried, clicked connect and I just get a bunch of gibberish that makes no sense and just continues to run on forever! Thanks in advance guys!
    -Dan
  2. Wildwelder
    Wildwelder Well-Known Member
    Is it trimmed peoperly? Props on correctly? I know these are obvious questions but I dont know your experience level.
    kookoocachoo likes this.
  3. DannyV
    When you say trimmed, what do you mean? I have my trims on my transmitter set to "0" and tranmistter calibrated. As far as doing an auto trim or auto tune, I haven't been able to get it in the air.
  4. Wildwelder
    Try moving the trim on the right stick. Centered isnt always perfect thats why theyre there. Try adjusting the trim so it wont roll on takeoff.(opposite the way it wants to roll). I hope this helps
  5. DannyV
    Thanks wildwelder, I'll give it a shot! What I've noticed is, when I try to take off, it begins to tip and will flip if I give it more throttle. If I try to correct it by counter acting which way it's tipping, then the next time I try to takeoff, it just tips in that direction instead. It's a never ending battle!! But I will definitely try what you reccomended! Thanks again, will post after trying tomorrow!
  6. DannyV
    so i tried using the transmitter trims and failed miserably! if i trim it to counter act the right tipping motion, it tips to the left and vice versa.....i'm about ready to give up! i've been trying to get this thing to fly for about a month now.....
  7. Wildwelder
    When you plug in the battery, is the quad somewhat lvl? Thats when it records what "lvl" is.
  8. DannyV
    yes, i try to find the most level area for potential takeoff
  9. Jackson
    What PC and OS are you using?
  10. DannyV
    I'm running Windows 7....I'm frustrated to the point I'm about to give up with this apm fc. Any advice?
  11. Wildwelder
    What quad/ transmitter is this anyway? Prob shouldve asked that first
  12. DannyV
    hobby kings sk450, apm 2.8, devo 7 tx and rx.
  13. Wildwelder
  14. DannyV
  15. Jackson
    Are you saying you've never been able to access the APM software?
  16. DannyV
    I've been able to set up and calibrate everything in the apm. I haven't been able to use cli in the terminal tab. It'll say "initializing apm", "barometer calibration complete" and "ready to fly." But after that it's just a bunch of gibberish. I haven't been able to fly my quad yet because it just flips on takeoff and I can't figure out why. I've tried everything!
  17. kookoocachoo
    kookoocachoo Member
    I once got loctite in my motors and it made them a bit screwy. You could check for that if you used any. I scraped it all off one but it was still operating funny. I just replaced them.
  18. DannyV
    I could open them and see if there's anything inside interfering with their function. But my quad flew fine with my ok 2.1.5 board. I just haven't been able to fly it since I installed the apm 2.8. Thanks for the advice!
  19. DannyV
    Here's a video of what my quad does...bare with me, it's in a basement because it's raining out. I'm also going to attempt to attach a video of what happens when I open the terminal. If anyone can let me know if this looks normal please! I'll also add pictures of how my quad is set up.
  20. RENOV8R
    I have no experience with APM or Ardupilot whatsoever, but it sure looks like your flight controller is just not doing it's job. Have you tried flashing the latest firmware and starting from scratch including all calibrations?
