Aluminum frame with landing shocks
Discussion in 'Frame Design' started by GJH105775, Dec 26, 2014.
  1. GJH105775
    Weight: 453.5 grams/ 16 oz (no electronics) or 1190.6grams/42oz (w/electronics)
    New weight: 255 grams without electronics
    Prop size (designed for): 9''
    Prospected weight when finished: 276.691 grams /9.7oz (no electronics) or 736.5 grams/ 25.97oz (w/electronics)
    [​IMG]
    The frame is not completed the spring is supposed to be in the aluminium tube. I chose to use a bolt so I could extend the landing gear and adjust the stop and spring tension.
    I plan to cast the ends in a mold and use square fibreglass tube as spreaders.
    [​IMG]
    Therefore 20 solid cubic inches of fibreglass weighs 1.1 pound, and 20 solid cubic inches of aluminium (alloy 6061 T-6) weighs 2.0 pounds. The frame would weigh approximately 0.61 pound. Of course the fasteners take up more of the weight.
    If anyone knows where I could get some sort of strong but lightweight composite/epoxy that can be molded/cast, I would REALLY appreciate it.
    [​IMG]
    UPDATE: Cut the weight down by almost half. I dropped the landing gear off and replaced them with simpler design. I can still bolt them back on if needed. i also had to add lights :).
    Click for pictures
    [​IMG]
    [​IMG]
    Here are my latest additions.
    Latest (Revision 4)
    I added a aluminium battery holder, the battery makes a nice click and is held pretty well, I'll probably add some Velcro to keep it in even better.
    I also added lighter legs that are bouncy (not finished in picture) and bolted the motors down, as the screws vibrate loose.
    [​IMG]
    [​IMG]
  2. Abdur-rehmaan Seba
    Abdur-rehmaan Seba electrolux
    Looks good, but rather heavy for the size don't you think?
  3. GJH105775
    A little perhaps, I did this more as a concept with cheaper material, I plan to build a lighter frame from fibreglass tube, it will weigh around 208.45 grams. My motors generate ~6ibs of static thrust and 2 of which will be taken up by the parts and accessories. That still gives me a 2:1 thrust:weight ratio.
    1/8 T x1 In OD Sq, 5 Ft Fibreglass tube
    Thanks for the input. I was wondering the same, if nothing else it will drain my already limited battery life. I have yet to decide whether to use fibreglass tube or cast it, I think I may cast the ends and use the tube for the spreaders. Do you know where to get any carbon-fibre/plastic channel or square tube?
  4. GJH105775
    One last thing, if anyone knows where I could get some sort of lightweight composite that can be molded/cast I would REALLY appreciate it.
  5. Abdur-rehmaan Seba
    Oh, I see 208 grams seems very light weight now!
  6. Abdur-rehmaan Seba
  7. GJH105775
    Thanks for the link, I don't believe that it is exactly what I want.
  8. sayed
    sayed Member
    mine is 26 grams but the problem is i cannot purchase brushless motor and i don't think brushed motor can work any solution will be appreciable
  9. sayed
    sayed Member
    did u tried hobbykings.com
  10. GJH105775
    Yeah, they did not have exactly what I wanted., I managed to cut the weight almost in half though. I updated the main post with pictures.
  11. sayed
    sayed Member
    i think u should visit a hardware shop near by you or you should deal with manufacturer if you have enough budget
  12. sayed
    sayed Member
    by the way nice design what is specification and price of your motors
  13. GJH105775
    Turnigy 150W 1240 KV motors I use 9x4.7 props. I should have went with 950kv - 1000kv motors to carry a little more weight. So I could swing a 10''-12'' props.
  14. GJH105775
    Added DIY battery holder, and landing skids. Because I was really hard on the others with my forward momentum.
