Hi all
I'm just starting to play about with air mode now, Iv run into two problems
problem 1
Iv set minimum throttle to 1040 but when airmode is turned on it stays around 1040, until I throttle up to around half way then instead of going back to 1040 when I drop the throttle. Motors 1 and 3 seem to slowly power up to full. I don't fancy testing it out side due to problem 2
problem 2
when airmode is turned on and I turn the controller off it doesn't recognise that its lost the signal, the motors are still spinning. If airmode is turned off and I cut power to the controller the motors cut out.
or is that just how air mode works I'm new to this stuff
iv not a clue what iv done wrong setting it up.
iv got
wizard x220
flysky fs-i6
on betaflight
if you have any ideas
problem 1
problem 2
iv got
wizard x220
flysky fs-i6
on betaflight
