Hi acro on a quad is not easy due to the fixed pitch of the props , a flip is the easy start give it power and then as it starts to climb pull back hard and fast on the cyclic ,as the quad flips reduce power or it will dive ground wards really fast keep the flip going as the quad comes up the right way add power ( this needs to be done at height to start off as it will loose height fast )
You stick scalling will need to be high so the quad flips fast , roll is the same do it fast reduce power as it goes upside down and add power as it comes the right way up ,this may help
